Welding of stainless steel pipes
Hi All
Have a question and sorry if it is irritant - is it mandatory to do 100% radiography test of welds for
stainless steel pipes (e.g. joint of two pipes or pipe and flange), and why?
Thank you
Thank you
RE: Welding of stainless steel pipes
The devil is in the details; she also wears prada.
If it is in the client's spec, you need to carry it out. This is not as per any piping code.
I give you an example for better understanding. Suppose CS piping is upgraded to SS and the service is rich amine. Well, the client removes PWHT however retaining the RT.
Regards.
DHURJATI SEN
Kolkata, India
Got a main picture - it is stated in Contract - must be 100%.
Thnx.
Best regards
