If you have connected to the ground
If you have connected to the ground using reference point, you can give temperature to that reference point by predefined field in analysis.
Good Luck
RE: If you have connected to the ground
You mean when creating a spring that is connected to ground?
No.
Workaround: Create a RP yourself somewhere, fix it with a boundary, attach the spring to it and then apply whatever you want there.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Evolving Landscape of Commercial Battery-Powered Trucks
What’s driving the evolving landscape of truck electrification? What are the barriers, motivators and strategies for accelerating the electric transition? What insights and resources are available for today’s design engineers working to achieve industry disruption and evolution? For answers to these and other pertinent questions, read this white paper. Download Now
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
