Breaking a 2d cloud of data points into straight line segments
GregLocock
Automotive
Orbiting a small yellow star
I recently found a couple of ways of doing this. They are not automatic, and i suspect they need some judgement in their use.
The first is from Matlab
and the second is the very neat SLM curve fitting toolbox
When i get matlab back then I'll be using these.
Cheers
Greg Locock
Here's a rather splendid piece of code that does most of what I need. That is, for a given set of knots in x0 it generates contiguous best fit straight lines for the x and y vectors. The result, p, is the y at the defined x0. What it doesn't do is measure the error, or attempt to move the knots to reduce the overall error. That of course, is what i need.
Code:
function p = fitPiecewiseLinearFunction(x, y, x0)
% Fit a piecewise continuous function f(x) to the pairs of data points (x,y)
% such that the sum of squares of error is minimal.
% x0 - values of x that define ends of segments of function f(x)
% p - end points of the segments p = f(x0)
% See also: [URL unfurl="true"]http://golovchenko.org/docs/ContinuousPiecewiseLinearFit.pdf[/URL]
% 4-May-2004 Nikolai Golovchenko.
numberOfParameters = length(x0);
% separate data in segments
j = {};
for i = 1 : numberOfParameters - 1
   j{i} = find(x > x0(i) & x <= x0(i + 1));
   if isempty(j{i})
      error('Insufficient amount of data points');
   end
end
% compute the matrices corresponding to the
% system of equations
A = zeros(numberOfParameters, numberOfParameters);
B = zeros(numberOfParameters, 1);
for i = 1:numberOfParameters
   if i ~= 1
      % first sum
      A(i, i-1) = A(i, i-1) - ...
         sum((x(j{i-1}) - x0(i-1)) .* (x(j{i-1}) - x0(i))) / (x0(i) - x0(i-1)) .^ 2;
      A(i, i) = A(i, i) + ...
         sum((x(j{i-1}) - x0(i-1)) .^ 2) / (x0(i) - x0(i-1)) .^ 2;
      B(i) = B(i) + ...
         (sum(x(j{i-1}) .* y(j{i-1})) - x0(i-1) * sum(y(j{i-1}))) / (x0(i) - x0(i-1));
   end
   if i ~= numberOfParameters
      % second sum
         sum((x(j{i}) - x0(i+1)) .^ 2) / (x0(i+1) - x0(i)) .^ 2;
      A(i, i+1) = A(i, i+1) - ...
         sum((x(j{i}) - x0(i)) .* (x(j{i}) - x0(i+1))) / (x0(i+1) - x0(i)) .^ 2;
      B(i) = B(i) + ...
         (-sum(x(j{i}) .* y(j{i})) + x0(i+1) * sum(y(j{i}))) / (x0(i+1) - x0(i));
   end
end
% find the parameters
p = A^-1 * B;
The black line is an eyeballed set of knots for the blue data. The circles are 11 year moving averages and the orange line is just a linear regression.
I looked at two built in functions. 'splinefit' tries to equalise the segment lengths. 'polyfit' doesn't guarantee that the lines are contiguous at the knots.
Cheers
Greg Locock
Try this. You can try several numbers of specified joints, and pick the 'Best' number based on rms error.
x=1:100;
y(1:25) = 0+rand(25,1);
y(26:50) = 1+rand(25,1);
y(51:75) = 2+rand(25,1);
y(76:100)= -1+rand(25,1);
figure
plot(x,y,'r.')
hold on
sp3=spap2(3,2,x,y) % 3 joints, 1st order( use a 2 for 1st order )
fnplt(sp3,'m')
 https://files.engineering.com/getfile.aspx?folder=20b527e5-015a-4ea2-89e6-7889d52fc5ea&file=Smoking_3_joints.JPG
Looks like elements derived from the Sunspot Cycle.
I should add I've got a rather horrible script that plots the error vs the number of knots and tries to optimise their location. it doesn't work very well
Cheers
Greg Locock
Settle on the number of knots the science seems to suggest, apply lsqcurvefit (Matlab) to the knot locations and turn the crank. I picked 11. Once you get the first solution, bootstrap it by perturbing the lsqcurvefit solution and send it back into the fire a few more times. I do this technique with Pacejka tire model fits and it works very well.
 https://files.engineering.com/getfile.aspx?folder=5231943f-49b1-4fde-893e-07c348f2b619&file=Knots_Landing.JPG
