TRANSFORMER POWER SUPPLY OUTPUT FREQUENCY HIGH AND ERRATIC
FOR A sTATIC IONISERR WITH ac ionisation, the TRANSFORMER WITH HIGH VOLTAGE LOW AMP. WAS MADE. bUT THE Supplier transformer fluctuates and shows up frequencies of 00 to 400 hz. Not sure what might be the issue. The voltages and ampere levels are decent. But, the sinusoidal freuency is not good. We filtered the input 20 v, 50 hz freq. and then the input was the primary supply to transformer. pl. help what could be the root cause.
RE: TRANSFORMER POWER SUPPLY OUTPUT FREQUENCY HIGH AND ERRATIC
TTFN (ta ta for now)
Keith Cress
We have a filter for removing the noise first.
