Worth it, especially when the size of material is larger than 1''. Wet saw can prevent over heat to temper your listed materials depending on the thermal history. Very low carbon plain steel, say 1003/1005, may not be a concern though.
I see lots of hardness failures due to sampling. Regrind .05'' off surface with sufficient coolant often make them pass.
