Spiral Bevel Gear-3D modeling_ReverseEng.
I need to create the 3D model (Reverse Engineering) from actual parts (pinion and gear Spiral Bevel set). How the tooth dimensions (such as pitch diameter, root diameter, form diameter, clearance, helix angle, etc, etc) can be extracted from the actual parts in order to create the 3D model of this set?. Does anyone know the typical procedure to follow?. I am thinking in "gear gauges" or special template for the tooth form and for the spiral angles (something like the thread gauges that can be superposed on the actual thread, so the thread can be identified). The basic "external" dimensions such as the major and minor diameter of the cone, the taper of the cone, tooth face width, number of teeth can be roughly be figured out, but what about the information to 3D model the tooth geometry?. Thank you in advance!.
RE: Spiral Bevel Gear-3D modeling_ReverseEng.
Thank you spigor!, the closer is: "Sample Application 3: Replicate an Existing Part", but there is not drawings available. Thank you for the information!.
Hi Fabian
I answer these post t help out, and to keep me sharp.
Ok to the point.
Do you have a gear shop to your disposal?
The new CNC gear checker's have an unknown reverse gear program.
Do the basics. And give it a head start.
Give it what it needs.
#teeth, tip diameter, Minor diameter
Ect.
The unknown gear program will give all the parameters.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Manufacturing the Cars of Tomorrow
In this ebook, we'll explore how additive manufacturing is going to transform the way cars are made. This includes commentary from thought leaders such as Ford's CTO, Ken Washington, Customer case studies of ways 3D printing is being used today, and a variety of part examples where 3D printing is already impacting how automobiles are made. Download Now
White Paper - Smart Manufacturing for Semiconductor
New technologies and approaches present great opportunities for semiconductor manufacturers to achieve high levels of innovation, yield and improvement. This white paper explores some of these cutting-edge technologies and how they can be applied effectively in the semiconductor industry. Read about how Smart Manufacturing is transforming the semiconductor industry. Download Now
White Paper - Analysis and Simulation in Aircraft Structure Certification
Organizations using simulation and analysis tools effectively see the benefits in their ability to achieve certification faster and with drastically less total cost than those who do not maximize these tools. Read this White Paper to learn about how digital tools such as analysis and simulation help in aircraft structure certification. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
