Concrete Shear/Bearing at Pile-to-Slab Interface
We are designing a pile supported slab that supports a building structure. The columns from the building sit directly above where the piles are with a 12" slab between to two elements.
In timber design, for shear, you can ignore loads placed within "d" of the support, where "d" is the depth of your beam.
Is there a similar provision in concrete design (ACI)? To me, it feels like direct bearing between the column base plate and pile below. By doing this, it would allow us to skip stirrups in this area (30% of load at pile is from building, 70% from self weight of slab and slab live load).
RE: Concrete Shear/Bearing at Pile-to-Slab Interface
Yes, there is a similar provision in concrete. Probably more so than in wood really.
What are the dimensions of your base plates?
What's the diameter of your piles?
HELP! I'd like your help with a thread that I was forced to move to the business issues section where it will surely be seen by next to nobody that matters to me: http://www.eng-tips.com/viewthread.cfm?qid=456235
I would sure consider thickening the mat locally at each pile head. Avoids the stirrups, as you were trying to do, and also provides easy, definite punching shear resistance for that High slab load bearing on the skinny Pile.
I agree about the column load being so close to the pile. Check bearing (easy), Make sure any complications due to pile installation tolerance will not cause problems.
Ebook - Mastering Tolerances for Machined Parts
When making CNC machined parts, mastering tolerances can be challenging. Are general tolerances good enough? When does it make sense to call out for tighter tolerances? Do you need a better understanding of fits, datums, or GD&T? Learn about these topics and more in Xometry's new e-book. Download Now
eBook – How to Choose the Correct Corrosion Testing Method
When designing a metal component, engineers have to consider how susceptible certain alloys are to corrosion in the final product’s operating environment. In a recent study by NACE (National Association of Corrosion Engineers), it was estimated that the direct and indirect costs of corrosion in the United States is approximately 6.2% of the GDP. In 2016, that cost exceeded $1 trillion dollars for the first time. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
