Integral nozzle hub thickness limitation
Does ASME follow any standard, which limits the thickness of hub. If yes, please guide me
Also, is there relation between the shell thickness and hub thickness as per ASME or any general suggestion
RE: Integral nozzle hub thickness limitation
Here's some guidance.
For ASME VIII Div 1, read UG-36 and Figure 37.1.
For ASME VIII Div 2, read Section 4.5 and associated figures.
DriveMeNuts
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
