Divider plate welded column splice
To transition from a 13l4" square x 1/2" HSS to a 12"square x 1/2" HSS, thinking of using a 3/4" divider plate, butt welded to 14" column and then 7/16" fillet weld upper col to divider plate- what do you guys think?
RE: Divider plate welded column splice
It sounds fine, especially if it's a shop splice. Obviously, the plate and the welds need to be designed for the real load effects acting on the connection. That said, the proportions of what you've proposed seem pretty stout so it's hard to imagine that you'll have any trouble.
HELP! I'd like your help with a thread that I was forced to move to the business issues section where it will surely be seen by next to nobody that matters to me: http://www.eng-tips.com/viewthread.cfm?qid=456235
Thanks, Kootk!
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
