Strange Spike Element
I am having trouble figuring out why one of my elements is acting strangely. I am working with a heterogeneous bone model simulating a compression test. After about a third of the step, one of the elements begins spiking out. The element is located far from the analytical rigid I am using to push on the bone (see the drawn red arch) or the constrained end. Any insight is greatly appreciated.
RE: Strange Spike Element
Check mesh quality in the Mesh module (Verify Mesh tool). This element may have poor quality parameters. Try refining mesh in this area. Also examine warnings and sets generated automatically by Abaqus. Some include severily distorted elements.
If this mesh was generated outside of Abaqus and then imported as orphan mesh, there might be an error in the import procedure. Or maybe it was generated with error already since the geometry is probably from scan.
Hi FEA way,
Yes I definitely have many distorted elements... no matter how clean I try to mesh this that has never changed. But I have never seen a spike like this. Could it be something different or because this is a bit coarser?
Indeed there are always some distorted elements but thanks to quality parameters (such as aspect ratio) you can find the worst element/elements. Such single element distortion may also happen when you apply some sort of wrong constraint. For example tie constraint with too high adjustment tolerance may result in excessive distortion of an element when it tries to merge it with neighboring node.
Check all your sets used for definitions of BCs, loads, sections etc. Maybe this element was mistakenly selected (or deselected) in some set.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Evolving Landscape of Commercial Battery-Powered Trucks
What’s driving the evolving landscape of truck electrification? What are the barriers, motivators and strategies for accelerating the electric transition? What insights and resources are available for today’s design engineers working to achieve industry disruption and evolution? For answers to these and other pertinent questions, read this white paper. Download Now
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
