Thickness of longitudinal baffles with lamiflex seals
As per TEMA R- 4.421 : "Longitudinal baffles with leaf seals shall not be less than 1/4" (6.4 mm) nominal metal thickness".
Does the above thickness apply to all pressure drop conditions?? How do we calculate the thickness of longitudinal baffle (with lamiflex seals) if the pressure drop is higher than recommended (i.e. 1.1 kg/cm2)?
RE: Thickness of longitudinal baffles with lamiflex seals
adilpervaiz, if you do not think 1/4" is sufficient, why not use the rules for welded long baffles, R-4.422?
Mike
Thankyou for your response, Mike.
We are not using welded long baffle due to maintenance requirements(ease of bundle pulling for cleaning).
To be more specific, i want to know how we can calculate the thickness of a longitudinal baffle (with lamiflex seal) for a shell side pressure drop of 1.1 kg/cm2?
Is there any formula to calculate the thickness of long baffle with leaf seals like the one given in TEMA R-4.422 for welded baffle.
Adil
adilpervaiz, there are no specific TEMA rules for leaf-seal long baffles other than R-4.421. You could perform the calculation of R-4.422, but likely the assumed edge conditions will not apply in the case of a non-welded long baffle. A "more accurate" calculation may be a calculation assuming all edges simply supported, such as Roark Table 26, Case 1 (6th Ed.) using appropriate characteristic dimensions. Another case may more accurately represent your exact configuration.
A couple of observations on my part:
1) You need to assure yourself that the lamiflex will hold a seal at your pressure drop, else the exchanger performance will suffer.
2) It is possible to have a removable bundle with a welded long baffle. It is messy.
Mike
Mike,
do you have an example of removable bundle with a welded longitudinal baffle?
I'm curious to see what it looks like.
Thanks!
CuMo, I don't have any drawings, sketches, etc, but can briefly describe the main features.
First, of course the cross baffles must be split to straddle the long baffle. Cross baffle cuts perpendicular to the long baffle are preferred, but not strictly necessary.
For floating head units, the floating head is split as well. TEMA has what appears to be a sketch of this arrangement, see Table A.131, sketch (k).
For U-tubes, the plane of the bends must be parallel to the long baffle. For more than, say, four tubeside passes this can become troublesome.
In any case, it is a messy business and a great deal of early attention must be paid to tube layouts, long baffle thickness, cross baffle arrangement, tie rods, seal bars, various clearances, etc.
Mike
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Criticality of the E/E Architecture
Modern vehicles are highly sophisticated systems incorporating electrical, electronic, software and mechanical components. Mechanical systems are giving way to advanced software and electronic devices, driving automakers to innovate and differentiate their vehicles via the electric and electronic (E/E) architecture. As the pace of change accelerates, automotive companies need to evolve their development processes to deliver and maximize the value of these architectures. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
Modern cars, trucks, and other vehicles feature an ever-increasing number of sophisticated electrical and electronic features, placing a larger burden on the wiring harness that enables these new features. As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - Modeling and Optimizing Wire Harness Costs for Variation Complexity
This paper will focus on the quantification of the complexity related costs in harness variations in order to model them, allowing automated algorithms to optimize for these costs. A number of real world examples will be provided as well. Since no two businesses are alike, it is the aim of this paper to provide the foundational knowledge and methodology so the reader can assess their own business to model how variation complexity costs affect their business. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
