Measuring complex area
CheckerHater
Does anyone know the way to measure combined area of multiple faces?
I can get surface area of the entire part from "mass properties" command.
I can get surface area of a single face using "measure" command.
But I cannot find command/setting to measure total area of multiple faces picked together.
Any advice will be greatly appreciated.
Does Mass properties not work for a single surface body?
When I select a flat surface my measure tool gives me the area of the surface.
Scott Baugh, CSWP [pc2]
CAD Systems Manager
Evapar
"If it's not broke, Don't fix it!"
faq731-376
"Measure" will give you the area of multiple selected faces...
you should just be able to control select the surfaces you want, then you measure tool will give you the total area for the selection
Thank you.
Silly me. For some reason "measure" wouldn't open the entire window, so area measurement still invisible.
And no, Mass property doesn't work with faces/surfaces, only with bodies.
Thank you again.
