Microgrid Generator Trip
Currenly reviewing an event for a small Microgrid system. Need some insight on the following scenario:
1. When the system became islanded, the diesel was started to provide aux power to start other engines.
2. Lead engineer #1 was started. (5MVA)
3. Then #2 and #3 were started to take loads. (2.5MVA each)
The issue was #2 and #3 would trip off under the scenaro. The geovenor setting has been thoroughly reviewed and appeared to be OK. Questions come to the Generator Relay. What protective elelment might cause the tripping? Unfortunately the trip report was not available.
Appreciate any comments.
RE: Microgrid Generator Trip
Like the computer said on Star Trek: "Insufficient information to draw a conclusion"
CR
Reverse power settings?
Bill
"Why not the best?"
Jimmy Carter
waross has the same initial guess that I did, assuming that 'governor settings' is applicable to all sets.
EDMS Australia
Governor settings:
Droop and speed:
Droop for a standby set is 3%.
Droop for a grid connected set is 5%.
Back in the day, the breaker on an incoming set was always closed when the synchro-scope needle was moving slowly clockwise.
If the needle was moving counter-clockwise you would get a reverse power trip.
If the meter was moving too fast clockwise you may get an over current trip.
If this is a new or recently changed installation there may be a wiring fault.
I have seen that also.
How do you synchronize?
Check the settings on an automatic synchronizer and/or a sync check relay.
Bill
"Why not the best?"
Jimmy Carter
Hi Bill, what you said; I was hoping to prompt the OP to start providing some of this information...
CR
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Research Report - How Engineers are Using Remote Access
Remote access enables engineers to work from anywhere provided they have an internet connection. We surveyed our audience of engineers, designers and product managers to learn how they use remote access within their organizations. We wanted to know which industries have adopted remote access, which software they are using, and what features matter most. Download Now
eBook - Managing the Context of Product Complexity Using the Digital Twin
Keeping track of changes to complex products is difficult—think Aerospace & Defense equipment, new generations of commercial aircraft, and software-based automobiles. A new way to managing the digital context of the physical product is required and the answer is the Digital Twin. This ebook explores the opportunity available for Operations and Maintenance for the Digital Twin. Download Now
White Paper - Trends in Industrial Filtration
Substantial progress has been made in filtration technologies in recent years. New filter media materials, designs and processes have led to filters that are more efficient, reliable, compact and longer lasting. This white paper will discuss the various trends that are impacting operational responsibilities of MROs today and the resources that are available for staying up-to-date on the latest filtration solutions. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
