Matlab for loop
mechMH
EG
Hi everyone,
i'm working on a code which has two 5*3 matrices,I want to add each column in say matrix "A" to every column in matrix "B"
so the resultant matrix is 5*9.
I'm doing it with FOR loop but it only returns the final column values. I hope if there are any suggestions!
If you are doing loops, bear in mind two things:
1) Pre-allocate your array (Greg's first line). Never grow it.
2) Realise that the neat and satisfying one-liners (vectorized solutions) don't have as much advantage over loops these days.
Steve
