bolted nut flange joint. FEM, STRUCTURAL, STATIC, ANALYSIS, ABAQUS
Hadrami_Hamdan
MY
HI.
first of all i want to admit that im quite new to abaqus and FEM, so hopefully with guidance i ill find my way.
problem faced:
1.step1- static analysis would not converge, and aborted by error
2.im finding a hard time to achieve an good aspect ratio mesh (goal is to get not more than 2 aspect ratio).
info on the model:
1.im doing a static single concentratted load which is acting at the middle of the stud type bolt.
2.the model analaysed is a sysmetry half of bolted joint.
3.component include;1.stud bolt,2. two nuts, 3. gasket, 4. 2 raise face falnge /welded neck
glad if anyone to give a hand on this issue.
attached is
1.error note in note pad
2.aborted screen shot
3.cae file
cheers :)
 https://files.engineering.com/getfile.aspx?folder=cafcea13-3efc-4601-8d1d-27c8aa8ac614&file=1.PNG
