In service welding.
In service welding.
To apply the recommendations in API 1104 - APP B - In service welding, it is mandatory that the fluid (oil, gas) must be flowing.
The problem we see is that applying welding on the outer surface without oil / gas fluid circulating inside the pipe, acting as a coolant / heat sink, could generate some type of fire / ignition / explosion inside the pipeline.
That is the reason we are looking for similar information and as warm as API 1104 - APP B, but without circulating fluid.
Any comment is grateful in advance.
RE: In service welding.
