Pump Foundation API RP686
Chapter 4 of API RP686 section 6.3 states that "The width of the foundation should be at least 1.5 times the vertical distance from the base to the machine centerline, unless analysis demonstrates that a lesser value will perform adequately."
Are they referring to the base of the foundation? Or the base of the pump/motor skid?
The base of the foundation is dictated by the client at 6" below frost, and top of concrete 12" above grade. Centerline of shaft is 43" above T.O.C., so the foundation width is almost twice as wide as the skid if they are referring to the base of the foundation - which isn't completely outlandish, but not what I was expecting....
RE: Pump Foundation API RP686
