Nastran - contact table
flyforever85
New member
Jun 22, 2010
178
I have 3 components that are glued to each other and I have to try different load cases but when I change the load case from Default, I can't open anymore that contact table because I receive this message:
Cannot select this contact table! The load case associated to the selected Load Step/Contact Table has a different number of contact bodies than the current contact table. They must be the same.
The contact bodies are always the same.
Any idea of how to solve this problem??
I think I found the solution: when I imported the loads into a new Load Case, I had to import also the contact properties. I always forget that the contact properties are part of the load group!
