Best way to check connected curves ?
Hello!
I have a pretty basic question.
I am trying to write a macro to check connected curves in the model, the old way to check is using the project curve feature and select a connected curve. it takes a lot of time if I have many curves.
can you help me another way to improve it
RE: Best way to check connected curves ?
Knowing what version of NX you're using would be quite helpful.
Tim Flater
NX Designer
NX 11.0.2.7 MP11 Rev. A
GM TcE v11.2.3.1
GM GPDL v11-A.3.5.1
Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
Are you working with edges on a body? If so, the .AskCnncEdges method might be helpful. It appears that it will only work with edges and won't accept curves (lines, arcs, splines, etc) as input.
www.nxjournaling.com
Thanks @Cowski ,i will try it
I tried, but it not work, can you help me fix my code, Thanks
I tried to write a demo code, change the color of the connected curve
CODE -->
using System;
using NXOpen;
using NXOpen.UF;
public class NXJournal
    static Session theSession = Session.GetSession();
    static UFSession theUFSession = UFSession.GetUFSession();
    static Part workPart = theSession.Parts.Work;
    public static void Main(string[] args)
		Curve[] theCurves = SelectCurves("Select connected curves");
        if (theCurves.Length == 0) return;
        System.Collections.Generic.List<Curve>[] sortedCurves = sort_by_connectivity(theCurves);
		DisplayModification displayModification1;
        displayModification1 = theSession.DisplayManager.NewDisplayModification();
        displayModification1.ApplyToAllFaces = false;
        displayModification1.ApplyToOwningParts = false;
        displayModification1.NewColor = 11;
        displayModification1.Apply(sortedCurves);
        displayModification1.Dispose();
    static System.Collections.Generic.List<Curve>[] sort_by_connectivity(Curve[] theCurves)
        NXOpen.Session.UndoMarkId markId1;
        markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "");
        System.Collections.Generic.List<Tag> theCurveTags =
            new System.Collections.Generic.List<Tag>();
        foreach (Curve aCurve in theCurves) theCurveTags.Add(aCurve.Tag);
        int n_joined;
        Tag[] joined = new Tag[theCurveTags.Count];
        theUFSession.Curve.AutoJoinCurves(theCurveTags.ToArray(), theCurveTags.Count,
            2, joined, out n_joined);
        System.Collections.Generic.List<Curve>[] CurveLists =
            new  System.Collections.Generic.List<Curve>[n_joined];
        for (int ii = 0; ii < n_joined; ii++)
            CurveLists[ii] = new System.Collections.Generic.List<Curve>();
            double min_dist;
            double[] junk = new double[3];
            double accuracy;
            int which = 0;
            theUFSession.Modl.AskMinimumDist3(2, joined[0], aCurve.Tag, 0, junk, 0, junk,
                out min_dist, junk, junk, out accuracy);
            for (int ii = 1; ii < n_joined; ii++)
                double this_dist;
                theUFSession.Modl.AskMinimumDist3(2, joined[ii], aCurve.Tag, 0, junk, 0, junk,
                    out this_dist, junk, junk, out accuracy);
                if (this_dist < min_dist)
                    min_dist = this_dist;
                    which = ii;
            CurveLists[which].Add(aCurve);
        theSession.UndoToMark(markId1, "");
        theSession.DeleteUndoMark(markId1, "");
        return CurveLists;
    static Curve[] SelectCurves(string prompt)
        TaggedObject[] selobjs = null;
        Selection.Response resp =
            UI.GetUI().SelectionManager.SelectTaggedObjects(prompt, "Select Curves",
            Selection.SelectionScope.WorkPart, false,
            new Selection.SelectionType[] { Selection.SelectionType.Curves },
            out selobjs);
        System.Collections.Generic.List<Curve> theCurves =
        foreach (TaggedObject aTO in selobjs)
            if (aTO is Curve) theCurves.Add((Curve)aTO);
        return theCurves.ToArray();
    public static int GetUnloadOption(string arg)
        return System.Convert.ToInt32(Session.LibraryUnloadOption.Immediately);
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Considerations for choosing a 3D printing technology
The adoption of 3D printing into major companies’ product development life cycles is a testament to the technology’s incredible benefits to consumers, designers, engineers and manufacturers. While traditional production methods have limitations in manufacturability, 3D printing provides unparalleled design freedom due to the additive method of building parts layer by layer. Download Now
White Paper - Are all 3D printed metals the same?
With so many different 3D printing metal systems and processes today, how can you know exactly what you’re getting? Today, there are several different methods for manufacturing 3D printed metal components with their own strengths and limits. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
