Same Ux on an edge
saeedfazeli
AU
Hi All
Please consider the plate with central hole tension problem. We need to apply a BC on the vertical edge that sets Ux=constant, so the vertical line should remain vertical. Then I apply a point force on edge. How could I do so? ( I use ANSYS WB )
Insert a remote force on the edge where you want to apply the load. Right mouse button on the remote force and choose ...promote to remote point. In the details of the remote point change behaviour to Coupled and activate only the x DOF.
