Vertical curve verification 1
trivedi123
I have transporter requirement for vertical curve is 7.5" in 50'.
I have A&E report showing profile of vertical . I need help to verify requirement.
Attached is the profile.
Any help will be appreciated.
 https://files.engineering.com/getfile.aspx?folder=03488123-7236-4fe3-82ca-89dff20dccf9&file=Vertical_curveCapture_-_Copy.PNG
Your transporter requirement being 7.5/(50*12)= 1.25% does not match any number grade number in the elevation plan.
If the concern is the transporter high-centering on a sharp vertical curve, then have no worry. That's a sag vertical curve, so you're only increasing the clearance underneath, between the axles. And it's a fairly gradual/long one at that for the algebraic grade difference, so should be navigable by almost any road-worthy vehicle.
If the actual longitudinal grade of the road is the concern then see chicopee's answer above.
Uh, that doesn't look anything like a vertical curve, trivedi...
It's nearly impossible to interpret those figures without accompanying text.
But a 7.5" chord offset to road surface is pretty clear. This equates to a 50' long vertical curve for a 10% difference in algebraic grade. It has a "k" value of 50/10=5.
The design has k values of 130 and greater, so they are much more gradual.
The sharpest curve has a k value of 130. The offset is 4" over a 200' chord, so is much flatter than the 7.5"/50 criterion.
Thanks CarlB,
Per Chicopee, 7.5"/50x12= 1.25%, according to you grade difference 10%. Is this related? My transporter requirement for vertical curve is 7.5" over 50'.Thanks.
Cont.
Also for sag curve the grade difference will be of subtraction of two grades, right?
Chicopee was guessing what the criteria was, stated that a change of 7.5" over 50' is 1.25%, a basic calculation of slope. But your criteria is for no more than 7.5" difference between a 50' long chord and the peak (or sag) on a vertical curve. Same result for a crest or sag, a 10% grade change results in a maximum 7.5" vertical difference between the chord and the curve. You'll have to study up on the definition of vertical curves to be certain.
I sort of mis-read the title. I was thinking that to verify a vertical curve for correct geometry, you would drive over it quickly with a weight on the seat next to you. A passenger will do. If the curve geometry is correct, the weight (passenger) will feel a constant vertical force throughout the curve, neither further rising or sinking into the seat, once the curve is entered. This is fun to test. Maybe not in your transporter, though.
Hey CarlB,
Sorry I am not civil engineer and I saw that vertical curve is function of parabolic curve. Is there a formula or method to calculate 7.5" in 50' has grade difference of 10% ?
Appreciate help.
The 7% in figure 58.1 is the maximum longitudinal slope mentioned in 25A.
25C is the maximum rate of change in slope. (the instantaneous slope at any two locations 6.5 ft apart on a vertical curve must not be more than 1% different.)
