Settingsun
Hi all,
I'm after opinions on whether the Direct Analysis Method of Design (DAM) set out in ANSI/AISC 360-16 (chapter C) is 'in accordance with' AS 4100. This would rely on AS 4100 clause 1.5.1 which in turn refers to section 3.
I think that the boxes in section 3 are ticked by DAM. DAM falls between the elastic and advanced analysis methods set out in AS 4100 which is another aspect in its favour IMO.
The main effect would be that the effective length factor for compression members (ke) is always 1.0 under DAM because the effects that increase ke above this are accounted for in the analysis, resulting in larger M* which compensates for the larger phi.Nc.
