Inconel 718 vs Inconel 718 plus
Joe Chen
New member
TW
Dear All
What is the difference between INCONEL718 and INCONEL718PLUS manufacturing (lathe/milling)
(eg rpm/feed/depth/machining time), could we use the same parameter for 718 to work 718 plus,
thanks.
Joe Chen... Inconel [nickel alloy] 718 I am very familiar with... however Inconel718Plus is a term I am unfamiliar with... sounds like basic 718 with proprietary processing of some sort.
There are forums that might be more appropriate for this question...
Metals & metallurgy:
Machining:
BTW... when discussing alloys, be prepared to present the alloy material specification. IE: the specification that materials are 'made-per' are all-important in discussions like this.
Regards, Wil Taylor
o Trust - But Verify!
