Residual Strength Composites- Last Ply Failure-Purpose Vs FARs.
Casilero
Aerospace
A composite structure in an aircraft is stressed to limit or ult as the case calls for. Defects are introduced during manufacture and may be inflicted on the aircraft in service. The materials test programme will establish acceptable levels of damage viz-a-viz the far field allowable strain. Hole allowables will be established by a bypass tool possibly.
However on a recent project, a tool was developed to calculate progressive destruction of a laminate to its last ply failure. The method involved applying a load to break the first fiber and then the matrix which ever came first, and so on sequentially.
The applied load regime was discussed among the people specifying the tool. An expert in composite residual strength (actually the composites programme chief) on a previous programme, questioned what this tool was for. His position was that we comply with FAR 25, static limit, ult, DT and that is it. We don't look to see what the remaining strength is after we have passed the specified FAR load so why develop a residual damage tool that could cater for up to 60 plies and give the load associated with the last ply failure.
Am I missing something? Perhaps a single load path subject to some kind of degradation or ply reduction by abrasion, one could establish if we are still meeting the load bearing requirement. Perhaps if the structure is overbuilt, then we could allow say scrapes of say 25% of thickness if justified by a residual damage tolerance tool to last ply fail.9.
The only one I can recall is the case of a landing gear door bracket lug in composite that had this performed for inflicted ply damage. And I may be wrong about this latter exercise.
Could this be really to establish MRB guidelines?
Slightly Baffled by need for this tool.
Can anybody give a real life example?
Para g of this EASA ref gives something or suggests something.
Assuming this is for carbon fiber composites,
And assuming well designed laminates with fibers in the load direction,
Then ultimate failure is driven by the fibers and any “predicted” matrix failures which occur before fiber failure are either wrong or insignificant. Therefore no need for progressive failure method.
Also, most aircraft structures are designed to open hole or damage allowables, which are ~ 50% of pristine.
Now, there are cases for large notch strength in laminates, for damage tolerance, where progressive damage analysis at the notch tips is required to correlate with test data.
Oh, and most progressive damage analyses are based on interactive failure criteria which have been proven, despite the text books, to be rubbish.
