NPSH available (NPSHa) and vapor pressure
Hello, this is my first time posting here. I hope this doesn't come off as a dumb question but here goes:
Premise
1.) NPSHa is the difference between stagnation pressure at the pump inlet, minus the vapor pressure associated with the temperature at the inlet.
NPSHa = Pstagnation - Pvapor
2.) Cavitation only happens when the stagnation pressure is less than or equal to the vapor pressure. In other words, cavitation starts to happen when Pstagnation=Pvapor , so cavitation starts to happen when NPSHa = 0
3.) The temperature at the inlet of the pump remains pretty much constant over various operating speeds, hence vapor pressure remains constant.
Questions
A. Why is NPSHr (NPSH required) anything other than it must be greater than 0? Because according to the premise, cavitation only starts when Pstagnation = Pvapor , so as long as the stagnation pressure is higher than the vapor pressure, no cavitation will occur.
B. Why is it said that NPSHr changes with pump speed? Recall that NPSH=Pstagnation-Pvapor , and the temp at the inlet is assumed to be constant, hence no change in vapor pressure at the inlet, so nothing should change. What am I missing?
Thank you
Premise
Questions
Thank you
RE: NPSH available (NPSHa) and vapor pressure
NPSHa is a fixed condition set by the installation, whereas NPSHr is set pump by design.
NPSHr is not the point where cavitation starts. Research "Incipient Cavitation". In order to be measured and documented, NPSHr is the point where the cavitation is sufficient to reduce the pump developed head by 3% (for most pumps) or 1% (for some high energy pumps, or if specified by purchaser). In either case, if NPSHr = NPSHa then there is already a significant amount of cavitation occurring. Thus, a margin is required in order to reduce the amount of caviation to an acceptable level.
Johnny Pellin
Read what JJ is telling you.
NPSH is NOT cavitation point. It is simply the point at which differential pressure dec re ases by 3% because onset of cavitation is very difficult to measure but differential pressure is easy.
You could be spot on NPSHA = NPSHR and be busy cavitating like mad.
Always best to add at least 1m and 2 if you can
It's always interesting asking a vendor if they have a cavitation curve as well as an npsh curve.
Sometimes it is close sometimes further away depending on flow.
https://herramientasdeingenieros.com/calculadora-d...
Thanks!
It should be:
NPSHa ≥ NPSHr
Where,
NPSHA = Psuction – Psaturation
NPSHa comes from the system while NPSHr comes from the pump. Note that you are comparing the differences of two pressures not the saturation pressure and suction pressure.
You really need to start your own thread and not hijack someone elses dead thread.
Mech eng - the thread ended 5 months ago....
LittleInch:
Thank you for letting me know that.
I didn't notice the date of the post itself and just replied since it was on top of the posts. I wonder why Matt1309 didn't create a new post. I will let the Admins decide on what to do with last few responses.
MechEng, thanks a lot for your answer
As you see from the above equation that NPSHA is dependent on vapour pressure.
SUppose, the fluid is boiling the Hatm will be equal to H vapour pressure and both cancels out each other, as in case of boiler feed pump.
Hence BFP application the static head should be high and the velocity shall be more in order to acheive the the difference between NPSHA and NPSHR.
ALso note that in case of suction lift H static is negative.
Hope the above clarifies.
A well phrased question has answers in itself!!!
