Contact US
Conversion of kW to Btu
I have seen over the internet that while converting kW to IP units, it appears like Btuh, while converting kWh to IP units, it appears Btu.
Why HOUR factor is considered while concerting kW to Btuh and why not when converting kWh to Btu.
RE: Conversion of kW to Btu
Because power and energy are related by time.
It is considered.
As noted the power has to be defined as energy divided by time
Heat power in IP units is BTU per hour
Heat power in SI is Joules per second. Joules per second is more commonly know as Watts.
Energy on the other hand is exactly that.
A KWh is just a useful unit so that people can get a grasp on what energy is being used over a set period. This can and really should be just called Joules. So 1KWh is actually 3.6 million Joules. That sounds like a HUGE number and once you get into big heat power it can make it look too big and then people make errors as to whether it is MJ, GJ, TJ
Because heat power in IP is in BTU/hr, to equate a KWh simply means converting Joules to BTU
So 3.6 million Joules is 3,412 BTU.
So it is the same thing, but just common usage has replaced some of the correct technical definition.
Thanks...
Also, as a clarification: Btu/hr is often written as Btuh. Hence your conversion from kW to Btuh (which is Btu/hr) is dimensionally consistent. kWh is actually kW*hr (analogous to Btu as a unit of energy), making the notation inconsistent with Btuh.
Btu is a unit of energy, kW is a unit of power.
Thanks to everyone....
I always remember that there is 3.413 Btu/hr per W. So there is 3413 Btu/hr per KW.
ElectroMechanical Product Development
(Electronics Packaging)
UMD 1984
UCF 1993
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
