concrete bonding adhesive
I'm reviewing a drawing where a new pedestal just 2 feet in height, 1.5' sqaure, is connecting to an existing slab on grade. Horizontal shear on pedestal is less than 3 kips. Drawing is asking to roughen existing and use bonding adhesive. Pedestal rebar will be doweled in using hilti epoxy. The use of bonding adhesive the I want to question in this case.
In case of new spread footing, pedestal is poured after footing hardens but no bonding adhesive is used.
RE: concrete bonding adhesive
Like you, I see the bonding adhesive as likely unnecessary.
In my opinion bonding adhesive is unecessary. As long as the surface is properly roughened, cleaned and has a saturated surface dry condition prior to placing the new concrete then you’re ok. Too many times I’ve seen contractors put the bonding compound on and then wait to place the concrete. The compound cures and you now have a bonafide bond breaker.
eBook - Efficient and Effective Production Support with 3D Printed Jigs and Fixtures
Jigs and fixtures offer manufacturers a reliable process for delivering accurate, high-quality outcomes, whether for a specific part or feature, or for consistency across multiples of parts. Although the methodologies and materials for producing jigs and fixtures have evolved beyond the conventional metal tooling of years past, their position as a manufacturing staple remains constant due to the benefits they offer. Download Now
Overcoming Cutting Tool Challenges in Aerospace Machining
Aerospace manufacturing has always been on the cutting edge, from materials to production techniques. However, these two aspects of aerospace machining can conflict, as manufacturers strive to maintain machining efficiency with new materials by using new methods and cutting tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
