Contact US
Gas density measurement
Is there a way to measure/infer gas density (say in kg/m3 unit) using an orifice type of instrument / flowmeter (that is, based on Delta P measurement) ?
Example: If I have a gas line that is equipped with pressure, temperature instruments and a flow element device (orifice), is there a way to obtain gas density from these only three physical devices and information ?
RE: Gas density measurement
Not possible I think. You still need gas composition to derive z from a simulator / with manual calcs. Else use an inline gas densitometer, especially if gas composition is expected to vary. If gas composition is fixed, there are many equations that can be used (Redlich Kwong, Virial, BWRS, SRK etc). Gas densitometers are notorious for producing erroneous results, which is why many operators prefer to use a online Welker gas sampler, then send on to a lab based GC to get the composition.
Thanks for the info.
What about ultrasonic flow meter ?
Ultrasonic and coriolis meters can output gas density also.
I have an additional question..
Is it possible to measure gas volumetric flowrate (Am3/h) using a flow element (orifice plate) instrument when the gas molecular weight / composition is unknow? Let us consider there are pressure and temperature transmitters installed on the gas line under consideration (with purpose of doing flow compensation).
Flow derivation with dp measurement across an FE requires a density input, so gas mol wt and z must be known or assumed.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
