Rotate a 3D view at 90/180 degrees
RE: Rotate a 3D view at 90/180 degrees
use the compass axis system (top right corner) snap it to your body, klick on the u,v,w letters (x,y,z counterparts in local system)
regards,
LWolf
LWolf,
Using the compass will move the geometry; I do not want that!
CAD 2015
sorry, missed one step... let go of the compass, but make sure it has the uvw retained, i.e do not drop it onto the bottom-corner-right point...
regards,
LWolf
LWolf,
I hate to loose your lesson, but I didn't understand your directions......
Is it possible to send me a step-by-step procedure?
Thanks a lot! dazed
CAD 2015
take the compass, place it on your solid. Notice that now the xyz have switched to uvw i.e local reference system based on your solid.
take the compass, and release it anywhere in 3D (anywhere BUT the low-right-corner...). the compass should fly back to its original position HOWEVER notice that it has retained uvw orientations...
you can now click on these letters (u,v,w) to rotate your CAD space.
To reset the compass back to global (x,y,z) coordinates, (there are several ways to achieve this) drop it onto the global axis located in the low-right-hand-corner.
regards,
LWolf
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Reliability Verification for AI and ML Processors
Artificial intelligence and machine learning are seeing growing adoption in a wide range of applications. ICs used for AI/ML applications are characterized by large parallel processing computation units, high power dissipation, and complex circuitry that can deliver maximum performance within a strict power budget. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
