change the text size of the dimensions
Hi.
I'm using UG NX11. I want to know how can i change the text size of dimensions in the sketches.
Exactly i want to make a screenshot of the sketch for my paper. But the text in the dimensions will get much smaller while Zooms in. How can i make the text size bigger and unchanged so that i can make a better screenshot.bigsmile
zz
RE: change the text size of the dimensions
I don't remember where but there
Is a relative text setting.
I have googled and tried to find some effective solutions(just like in the picture above). But didn't work.
Use fixed text height on screen and set the value of text height which will suit your requirement.
Ravi
Thanks Ravi. Problem solved.
Zhen
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Close Box
Join Eng-Tips® Today!
Join Us             Close
