Corroded piping collaterally detected
Dear mates,
Question:
During the evaluation of radiographic welds, the piping base material was observed corroded.
That indication should be evaluated under the provisions of what code.
Any input will be appreciated.
RE: Corroded piping collaterally detected
Depending on the parts which was fabricated under certain Codes, for example, pressure piping under B31.1/31.3 codes, pressure vessel under ASME VIII, tank under API-650, etc. It could be under the visual inspection as required per Code.
Suggest to consult with Material Engineer or perform a failure analysis to understand the root cause.
If the piping is in operation, and it is desired to keep it in operation, then API 579-1/2 or BS 7910 is a better bet.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
For clarification:
Piping system construction is on going all piping and fittings were expected to be brand new.
What code are you building the pipe to? That is the answer. Use the acceptance criteria for new pipe, and/or if it refers in the code methodology(s) to assess corrosion (such as ASME B31 or API 579) use this to assess.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - 10 Reasons to Choose CATIA on the Cloud
To compete in today’s fast-paced and competitive market, smaller and newer firms need a powerful platform that will enable them to compete with bigger players, without the heavy investments needed in computer hardware, software and personnel. Download Now
White Paper - Smart Manufacturing for Electronics
This white paper describes a transformative approach to electronics manufacturing made possible by the addition of Mentor Graphics to the Siemens family. It describes a completely digitalized strategy that supports both printed circuit board (PCB) and mechanical design and manufacturing, uniting the entire product lifecycle – from idea and production to customers and back. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
