Hi
I'm trying to create new part without an Inerface 'new dialog'.
but I get this error:
'Line 27: 'NXOpen.UF.UFPart.Friend Sub New()' is not accessibile in this context because it is 'Friend'.
PLEASE CAN SOMEONE HELP.
This is the journal I'm using
Thank you.
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module create_new_part_uf_part_new
Sub Main()
Dim s As Session = Session.GetSession()
Dim ufs As UFSession = UFSession.GetUFSession
Dim theUI As UI = UI.GetUI
Dim lw As ListingWindow = s.ListingWindow()
Dim workPart As NXOpen.Part
Dim displayPart As NXOpen.Part
Dim part_name As String
Dim part_tag As Tag
Dim units As Integer = 1
part_name = "a1b2c3d4e5f6"
Try
ufs.Part.New(part_name, units, part_tag)
Catch
End Try
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
End Function
End Module
Thank you.
