Abaqus warning-Geometric non linearity for solutions of crack problems
Hi
Is there any points to consider while conducting geometric non-linearity in cracked plates when the aim is SIF calculations.
Abaqus issued the following warning which raised my concerns
K factors output has been requested in a large deformation (*step, nlgeom) analysis. The results might not be accurate.
there was quite a stability in the convergence of the step increments provided that kind of large steps (0.1/ 10 steps) have been adopted
RE: Abaqus warning-Geometric non linearity for solutions of crack problems
It's just a warning. K factors are only valid for linear problems, so the warning is to be careful when you might have large deformation (possible with NLGEOM).
so what's common to use in case of NLGEOM instead of K1?
Is J-Int still valid in this case?
If I want to compare 2-cases with/and without NLGEOM which fracture parameter could be adopted from FE results?
Yes, the J-integral can be used in nonlinear cases. For linear cases it is equivalent to the K factos. You find more details on that in books or papers on fracture mechanics.
Mustaine3
Provided that we calculated the J-integral from the nonlinear geometric analysis. can we derive the SIFs from the J-integral in Abaqus, please?
It seems that the deviation for linear cases available, in such cases NLGEOM is it same derivation of SIF from J integral?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Implementing a Multi-Domain System
IoT systems are multi-domain designs that often require AMS, Digital, RF, photonics and MEMS elements within the system. Tanner EDA provides an integrated, top-down design flow for IoT design that supports all these design domains. Learn more about key solutions that the Tanner design flow offers for successful IoT system design and verification. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
