WQT per ASME sec IX
WQT per ASME sec IX
WQT per ASME sec IX
Respected experts!
please give your kind opinion on following matter:
I want to run a WQT as per ASME IX, what is the acceptance criteria for a WQT with reference.
As per my understanding to qualify a WQT both options from following must be satisfied per QW 304.1:
a) Visual acceptance
b) Mechanical or volumetric testing
But what will be the acceptance criteria for visual per ASME IX. as QW 304.1 do not refer any clause for visual acceptance criteria. will it be QW 194?
RE: WQT per ASME sec IX
Faree
By WQT, do you mean a Welder Qualification Test? Section IX refers to this as a WPQ or Welder Performance Qualification. If so see QW-144 & QW-194.
The acceptance criteria is mentioned in QW 194. However the construction code visual inspection acceptance criteria to be fulfilled in addition(recommendation only)
Quote (Faree)
This needs correction. QW-304.1 requires:
a) Visual and Mechanical Testing -OR-
b) Volumetric Testing - Visual not required
If you choose a) then that leads you to QW-302.4 for visual requirements, which leads you to QW-194 for acceptance criteria.
The devil is in the details; she also wears prada.
QW-320 & 321 provides this information, which is summarised below: Immediate Retest Using Visual Examination A welder who fails to satisfy the visual examination criteria for a welded test coupon is allowed an immediate retest but must make two consecutive test coupons, for each test position failed, and both must satisfy the visual examination criteria. Why are we doing a visual when can just do a volumetric test. No visual exam needed on test coupons if you are going to perform a volumetric, really? Am I missing something here.
I always included visual examination during and after the welder qualification. If a welder cannot make an acceptable root pass on a pipe weld qualification, why would I want him/her to make production welds? The purpose of welder qualification testing should be to assure his/her capability to make sound production welds, not just to put another body on the payroll. I've seen cases where management simply wanted more welders because they did not have enough manpower and visual examinations were relaxed and the repair rate skyrocketed. With multiple rejections requiring welder terminations, additional welder testing costs were also incurred.
Exactly.....almost all welds are visually inspected in production. Do you really want a welder that can't pass visual?
I agree that visual testing should be done. However, in this case, it is in fact not a shall. That is, when performing volumetric testing.
gtaw made a very excellent post about this double posted question.
https://www.eng-tips.com/viewthread.cfm?qid=448383
I completely agree with his sentiments:
1. ASME IX Visual Acceptance Criteria is sparse at best.
2. The code of construction Visual Acceptance Criteria is better, and should be used.
3. This practice should be agreed upon by all parties.
Wow, everybody seems to be onboard with this one, that's great. Although the code is a little lacking in visual inspection criteria, my company uses approved welding specifications / standards that are a little above the code requirements for welding and rest assured that visual weld inspection criteria from the test shop to the field is thouroughly addressed for all welding.
I agree DVWE.
As mentioned sec IX is vague.
At our shop we go with the lowest service category for B31.3 as far as visuals are concerned.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
White Paper - The Criticality of the E/E Architecture
Modern vehicles are highly sophisticated systems incorporating electrical, electronic, software and mechanical components. Mechanical systems are giving way to advanced software and electronic devices, driving automakers to innovate and differentiate their vehicles via the electric and electronic (E/E) architecture. As the pace of change accelerates, automotive companies need to evolve their development processes to deliver and maximize the value of these architectures. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
