Reading & comparing Input files
Hi
I am calculating the stress intensity factor for cracked models. General procedure for modeling crack using Abaqus example with photo here Link
In My model, The program runs correctly for one case (crack length =x). for other cases when the crack length increased, I got unexpected & inaccurate results: The assigned seam crack did not open through its whole length. Changing the mesh, the part (near crack tip, or near the edge) that open, and the length of the opened seam change. simply the whole seam crack should open. There is no error by Abaqus (should be there is an error for such case). The problem described with a photo in this thread:
Link
I want to see if there is a difference in my of my modeling steps in the successful run model and the failed ones. I guess this can be done by comparing the input file or the data file.
how to compare & find if there is a difference in the main procedure of two models provided that the crack length is different. Simply I want to check the main procedure, the way created Parts, assembled them, merge/cut them.
Even though I pretty sure I adopted the similar procedure in both models, but wanna found the explanation for this problem.
Thank you
RE: Reading & comparing Input files
Typically an FEA program dumps the model into a text file (f04 and f06 for Nastran I think). Your job is to compare those text files for the two runs. This is agony, use a program like winmerge, gdiff, or beyond compare.
Cheers
Greg Locock
Comparing Abaqus input files is simple. Good editors can do that, also tools like Total Commander or tools that are specific for that task (UltraCompare, e.g.).
Comparing how the model was created in A/CAE is not so easy or even possible in general. You could compare the .jnl files, but I think that is not working for every situation. Even a manual check of the entries in the model tree cannot cover all possibilities.
If you just want to compare two textfiles a simple approach may be command "fc" in windows command prompt.
Thomas
can't you view model deformed shape ? or stress around the crack ? that'll show that somewhere your crack has been "welded".
comparing f06 files is sooo olde school ... something I might have done (coming from that school) !
For comparing two text files, when you want to find and examine lines with differences, I recommend:
Import or copy and paste both files into adjacent columns in a spreadsheet, with settings so that each file goes into one column.
In a third column enter a formula like IF(TRIM(A1)=TRIM(B1),"","********")
Copy down to the bottom.
Any different lines will now be tagged with *******.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
Notepad++ with Compare plug-in is very useful for input file comparison.
Quote:
There's no need to get a separate utility; any of the Office suites' word processors should have a text compare.
Thanks, I hadn't noticed that before.
I still prefer doing it in Excel with a formula though :).
Doug Jenkins
WinMerge for Windows and Meld for Linux, I always use them.
https://welsim.com
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
