The Seam crack open partially!:modelling issue
ABD01
MD
Hi
As you can see in the attache that the seam crack opened partially. just the part near crack tip. This part is partitioned circle merged in an assembly of same material. You can see that the element separated at the line of partition. There is no error. warning some far element distorted. results do not make sense as it is not for the whole length crack, just represent that opened part. What am I missing here.I already run similar model 3days ago and worked. I built on the same model, also started from beginning, checked the assigned seam crack region correctly, but no success yet.
One thing is the partition around crack seems as an exterior edge as it highlighted as the exterior edge /yellow lines. check the node duplication but not exisit. I did merge the parts in teh assembly, but not sure what else to check.
Thank you
 https://files.engineering.com/getfile.aspx?folder=dfb6b67e-3eaa-4d72-b1dd-5dedf23ff1f3&file=Crackseam.PNG
