Load cells
Load cells
I'm not sure which forum is the most appropriate for this topic?
I want to use an S-type load sensor (in tension), but am not familiar with them.
> Is the load intended to be applied to the U-shaped openings, with the tapped holes to be used for load-link retaining bolts?
> Is packaged circuitry readily available to provide an analog output of 0-5 volts DC that is directly proportional to the applied force?
RE: Load cells
https://www.hbm.com/en/6768/what-is-a-load-cell-an...
https://www.omega.com/prodinfo/loadcells.html
Follow the links on the Omega site for tutorials. You have a lot to learn.
RE: Load cells
RE: Load cells
> Do they typically contain a Wheatstone bridge, or merely the piezo strain gauge?
> To obtain an analog 0-5 VDC output, are there pre-engineered circuits available for purchase?
RE: Load cells
Strain gage amps are readily available in all sorts of forms and prices. Hobbyist ones are as little as $7, proper ones can be $1000 (or more, no doubt)
https://circuitdigest.com/microcontroller-projects...
Cheers
Greg Locock
RE: Load cells
RE: Load cells
RE: Load cells
Edit: Got my notes mixed up. AD620 is by Analog Devices Inc, not TI.
______And I forgot to ask if supplying the same +5V to both the in-amp and the bridge is okay?
RE: Load cells
New question- Are S-type load cells made with mechanical internal stops to prevent over-stressing the strain gauges?
I wonder if I did harm by applying a 136 Kg force (tensile) to a 100 Kg-rated cell?
RE: Load cells
Thanks.
RE: Load cells
Bill
"Why not the best?"
Jimmy Carter
RE: Load cells
je suis charlie
RE: Load cells
The strain gauge should be properly prepared by ideally gluing the strain gauge to the material being tested. The glue used should be specially prepared for use in the strain gauge. Its thickness should not exceed 10 micrometers. The operation of the glue should isolate the wires from the material being tested. The glue should withstand high operating temperatures without changing its physical and electrical properties. After proper gluing of the strain gauge, the whole system is covered with a protection layer, it may be a wax.
