NXOpen.NXException: First parameter is invalid
Hi
I get this error:
for the blockstyler command:
or this command:
Can someone HELP or give me a hint about the resion.
Thank you.
I get this error:
CODE -->
listBoxName.SelectedItemIndex = 6
or this command:
CODE -->
listBoxName.SelectedItemIndex = listBoxType.SelectedItemIndex
Thank you.
RE: NXOpen.NXException: First parameter is invalid
The error occure at RUNTIME
Do its possible that this because listBoxName is empty
And I try to insert a data in the middle of an empty listbox.
What I'm trying to is this:
I have two listboxes one js the master and is contains data.
And one is slave and is empty.
Now the user selects any item from the master listbox the selected item
Go to a string box for editing and after user editing
I need to insert it in the slave box at the same index as master listbox.
Containing items.
And still get that error.
Can someone give a clone.
SelectedItemIndex
Without success.
Do anyone know how to use this
Blockstyler property.
Thank you.
Only possible solution I could think of is that you, every time the function is accessed, clear the list of entries and fill it with a new list where the changed value is at the correct position.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
And thank you very much.
That was my thinking and last solution.
Because If the list is very big
it will take very long time.
Thank you again for supporting me.
