QW-200.2(f)
QW-200.2(f)
QW-200.2(f)
Hi experts,
I have two PQR'S
1) GTAW : Deposited weld metal 7mm
2) SMAW + GTAW : Deposited weld metal 70mm, GTAW (16mm), SMAW (54mm)
QUESTION : Can I make WPS Qualification ranges FROM 1.5 TO 200, Deposited weld metal GTAW(max 32mm), SMAW (max 200mm)?
AS PER QW200.2(f): yes
As per QW 200.4(b): No
Brown
RE: QW-200.2(f)
No...because SMAW is qualified for 5mm - 200mm BM. It is not qualified for 1.5 - 4.99mm.
RE: QW-200.2(f)
Thanks David
If I have 3 PQR's
I have three PQR'S
3) SMAW : Deposited weld metal 7mm
Brown
RE: QW-200.2(f)
That looks good.
RE: QW-200.2(f)
What about PWHT?
Regards.
DHURJATI SEN
RE: QW-200.2(f)
PWHT will be dictated by the construction code....not part of this thread.
RE: QW-200.2(f)
PWHT is an essential variable. See QW-407.1 applicable to both the stated processes.
RE: QW-200.2(f)
Yes, and in this case it is "NO PWHT". Just because a WPS is good for 8" doesn't mean it requires PWHT.
RE: QW-200.2(f)
While you can do it, why do you really want to? Will it be more confusing to a welder who may weld thicknesses between 1/16" and 3/16? Will he try to make such groove welds with both processes on such thin material? And do you really want him to do so? While I realize your desire to reduce the number of WPSs, sometimes it is better to have more to provide the welder (and inspectors) more specific info to reduce errors nd costs. On one construction project, I saw welders who completed the GTAW portion of a weld only to wait, doing nothing, for the SMAW fill crew to arrive when the weld could have been completed with but one additional layer of GTAW taking about 5 minutes.
RE: QW-200.2(f)
Please remember the primary reason for having WPS's is to provide guidance to the welder (as Weldstan has noted).
More info - better result.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Research Report - How Engineers are Using Remote Access
Remote access enables engineers to work from anywhere provided they have an internet connection. We surveyed our audience of engineers, designers and product managers to learn how they use remote access within their organizations. We wanted to know which industries have adopted remote access, which software they are using, and what features matter most. Download Now
eBook - Managing the Context of Product Complexity Using the Digital Twin
Keeping track of changes to complex products is difficult—think Aerospace & Defense equipment, new generations of commercial aircraft, and software-based automobiles. A new way to managing the digital context of the physical product is required and the answer is the Digital Twin. This ebook explores the opportunity available for Operations and Maintenance for the Digital Twin. Download Now
White Paper - Trends in Industrial Filtration
Substantial progress has been made in filtration technologies in recent years. New filter media materials, designs and processes have led to filters that are more efficient, reliable, compact and longer lasting. This white paper will discuss the various trends that are impacting operational responsibilities of MROs today and the resources that are available for staying up-to-date on the latest filtration solutions. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
