Extrude Geometry - Dimension Gets Priority
Greetings:
When I sketch to make a solid body, as I'm selecting the geometry, if it is near a dimension, the dimension gets selected first, which, a dimension cannot be used to extrude, but yet it tries to select it. Is there a way to turn this off or re-prioritize the entities you wish to select.
Brent
RE: Extrude Geometry - Dimension Gets Priority
You can do a couple things here.
* You can set your filter only to curves.
* In your search feature in NX enter Selection Priority, and you will see the CNTRL SHIFT functions that are associated with what gets the highest selection priority.
Jerry J.
UGV5-NX11
Thanks Jerry
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Implementing a Multi-Domain System
IoT systems are multi-domain designs that often require AMS, Digital, RF, photonics and MEMS elements within the system. Tanner EDA provides an integrated, top-down design flow for IoT design that supports all these design domains. Learn more about key solutions that the Tanner design flow offers for successful IoT system design and verification. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
