Export counter-warped geometry
Good morning,
I am a new user of Abaqus and I am having some difficulties when trying to export the inverse deformed shape of a part after an analysis. I am using Abaqus CAE to apply a temperature field in a part, generating the correspondent deflections. I know that I can invert the deflections using a negative scale factor, but I would like to know, if possible, how could I export this counter-warped geometry, so I could import it as an original part for following studies. I know that I can import the deformed part from the ODB file, but I would like to import the deflections with a scale factor of -1. I have been looking in the manual and different tutorials but I cannot find what I am exactly looking for.
Thanks for your help.
RE: Export counter-warped geometry
Not sure because when you import the ODB file (in Part/Instance), then it is the true deformed mesh. Not sure how you can scale it with -1.
In another post there is a python script for exporting deformed mesh (Link)
Not good with that so I can not tell how it works. I believe though that one main line that needs to be changed at least is: defNodePos = curNode.coordinates + dispField.values[i].data to defNodePos = curNode.coordinates - dispField.values[i].data .
Good luck
I have modified slightly the script from the above link and made a reference example to export an input file (for shells only). The file needs to be in the same folder as the .odb files, and the scale factor (called scalefactor in the script) needs to be set in order to scale the deformed mesh. Obviously this is just a reference example only, but feel free to have a go and see if you can tailor it to your needs.
CODE --> Python
from abaqus import *
from abaqusConstants import *
# create odb object from odb file
outputDatabase = session.openOdb(name= 'Platedefromed'+'.odb')
# get access to the nodal displacement data
frame = outputDatabase.steps[ 'Step-1' ].frames[-1]
dispField = frame.fieldOutputs['U']
# get access to the part instance -- thru which u can access the undeformed nodal position coordinates
my_part_instance = outputDatabase.rootAssembly.instances['PART-1-1']
# Write deformed shape to inp file
# NOTE: if you want to export to a different file format, you should appropriate code for that file format here
outFile = open( 'deformed_shape.inp' , 'w' )
# write inp header
outFile.write( '\n*Part, name=PART-1-1' )
scalefactor= 1.00
# write nodes
numNodesTotal = len( my_part_instance.nodes )
#outFile.write( '\n\nPOINTS ' + str( numNodesTotal ) + ' floathiiii' )
outFile.write( '\n*Node\n' )
for i in range( numNodesTotal ):
	#outFile.write('Hi\n')
	curNode = my_part_instance.nodes[i]
	defNodePos = curNode.coordinates + scalefactor*dispField.values[i].data
	#for j in range( 3 ):
	outFile.write( str(i+1)+','+str( defNodePos[0] ) + ',' + str( defNodePos[1] )+ ',' +str( defNodePos[2] )+'\n' )
# write shell elements
numElementsTotal = len( my_part_instance.elements )
#outFile.write( '\n\nCELLS ' + str( numElementsTotal ) + ' ' + str( numElementsTotal * 5 ) )
for i in range( numElementsTotal ):
	curElement = list( [i+1] + list( my_part_instance.elements[i].connectivity ) )
	numbernodes=len(curElement)
	outFile.write( '\n*ELEMENT,' + 'type='+'S' + str(numbernodes-1))
	outFile.write( '\n' )
	for j in range( numbernodes ):
		outFile.write( str( curElement[j] ) + ',' )
outFile.close()
outputDatabase.close()
Good morning Erik, thanks a lot for your help.
Unfortunately, I had never worked with Python files so I am not able to change it as I want. I have tried the script but I don´t get the values for the nodes. The principal problem is that my part is a solid, not a shell, but I don´t know how can I modify the script to get the nodes for the solid and if it would be far different from this one.
Thanks again
Hi I am not an expert in Python either :).
For 3D elements you should just need to change line 54 from outFile.write( '\n*ELEMENT,' + 'type='+'S' + str(numbernodes-1)) to outFile.write( '\n*ELEMENT,' + 'type='+'C3D' + str(numbernodes-1)).
If you have some reduced integration 3D elements then you might also add +'R' in the end that is: outFile.write( '\n*ELEMENT,' + 'type='+'C3D' + str(numbernodes-1) + 'R').
The file needs to be in the same folder as the .odb files, and the scale factor (called scalefactor in the script) needs to be set in order to scale the deformed mesh. The input file generated is in this folder also and is called, deformed shape.inp.
To run the script, go to your model (not output and visualisation module), and go to File/Run script... and select the .py script. That works.
White Paper - Guide to Integrate Large-Format Additive
As with any new technology, getting into large-format 3D printing begins with investigation. The first question may be a simple one: what does “large-format” mean? For 3D printers, “large” is a relative term. Many extrusion-based (FFF) 3D printers are referred to as desktop machines, because they fit on table space. Some of these have very respectable build volumes – but when it comes to “large-format,” the machines will need their own dedicated floor space. Large-format 3D printers have significant build volumes and are most often found in professional settings, like manufacturing facilities and R&D centers. Download Now
eBook - Efficient and Effective Production Support with 3D Printed Jigs and Fixtures
Jigs and fixtures offer manufacturers a reliable process for delivering accurate, high-quality outcomes, whether for a specific part or feature, or for consistency across multiples of parts. Although the methodologies and materials for producing jigs and fixtures have evolved beyond the conventional metal tooling of years past, their position as a manufacturing staple remains constant due to the benefits they offer. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
