Draftsight 2018 hatch trimming issue...
So, got tired of subscribing to Autocad LT every year, thus trying draftsight, the free version. So far everything seems to work as in AC except the trim command with hatches. I’ve asked in the Draftsight forum, gotten no answers, looked in the DS help section, not very informative and done google searches. The only entry that specifically deals with this issue is in this forum, which I tried, but does not work for me. Maybe I am not understanding it or it is applicable to previous releases.
If I have a square, for example,and I hatch it and later want to trim off part of that hatch there is no way I’vebeen able to do it as in Autocad, by just drawing the trim line to define the cutting edge and voila, there goes the hatch to be trimmed. So can this be really done in DS, or is there something more complicated that I am not aware? Help will be appreciated!Thanks
RE: Draftsight 2018 hatch trimming issue...
I don't use the hatch command very often, so this may not be the best or only way to do it, but I did find a way to trim the hatch. I've attached a simple dwg file showing how I managed it, but here are the highlights:
Create your hatch and draw your trim line.
Select the hatch and right click then select hatch edit or simply type hatch edit in the command prompt.
Specify a point outside of your trim line, but inside of the existing boundary and "enter" out of everything.
From my little bit of research it appears that for this to work the original boundaries of the hatch must still exist. This means that you need to wait to trim the boundary lines until after you trim the hatch.
Hope that helps
Maybe I am missing something but is not working. I cannot specify that point outside of the trim line if you could be more specific I would appreciate it.
I think that it has something to do with the internal regions settings with hatches.
I have updated the drawing to hopefully be more clear and am also including a picture of my hatch settings.
