Is there a way to work on projects that are 4 or 5 Km in size in NX ?
I don't remenber the settings to be able to work on projects that are 4 or 5 Km in size in NX ?
Or maybe it's not possible
Thanks in advance
Didier Psaltopoulos
http://www.psi-cad.fr
RE: Is there a way to work on projects that are 4 or 5 Km in size in NX ?
You can find it in Customer Defaults - Gateway - Visualization - View/Screen
Increase the value for "maximum Size for an objects Bounding box"
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
Or draw a sketch line and give
it your big dimension
I might be wrong, but I think the 1 km side length cube is a hard limit on the modeling space. For anything larger, you might need to work on a scaled down version.
www.nxjournaling.com
Hi Cowski,
I have tried and found that the limit is 500m side length
Didier Psaltopoulos
It is a 1km per side cube, centered on the absolute origin. Limits would be -500m to +500m in the X, Y, and Z directions.
Hi Cowski,
Thanks a lot
Didier Psaltopoulos
What happens when you try to create something that is 5km long ?
Jerry J.
UGV5-NX11
Hi Jerry,
You can play with my part: the sketch is editable, but it's not possible to extrude it
Didier Psaltopoulos
The parasolid limit is 1km cube, centered around the ABS 0;0;0.
But, you can position components further away than that.
I hope that Siemens somehow changes this definition, the company i work for frequently struggles with the 1km3 limit.
The accuracy in NX is , for our purposes , well enough even if we would consider "1" as 1 meter instead of 1 mm.
regards,
Tomas
If something is of size 5km then
chances that it is repeatable
are close to 100%
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Implementing a Multi-Domain System
IoT systems are multi-domain designs that often require AMS, Digital, RF, photonics and MEMS elements within the system. Tanner EDA provides an integrated, top-down design flow for IoT design that supports all these design domains. Learn more about key solutions that the Tanner design flow offers for successful IoT system design and verification. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
