I need some help trying to visualize a discussion I am having with a colleague.
At a constant speed, will the approach of an aircraft at a steeper angle be more or less stable then a shallow/flat approach that is reliant on thrust in order to maintain lift?
The way we are visualizing the issue is, in the shallow or flat approach, if the aircraft is reliant on engine thrust to maintain flight, for instance at a 2% approach - it would have less ability to respond to deviation in the flight condition. However, if it takes a steeper angle, say 7 or 8%, while maintaining the same constant airspeed as the 2% example, the AoA would be higher and therefore have a higher drag coefficient in the steeper approach.
Please help us understand.
