I'm working in an area where existing foundations were specified to be constructed with Type V Sulfate Resistant Concrete with slag or pozzolan and maximum 0.4 water-cement ratio.
The soil is highly corrosive and contains sulfates.
Unfortunately the specification was ignored. Deterioration of the concrete could begin to occur within five years.
I'm planning to recommend excavation, where possible, and coating the tops and sides with bitumen coating, to the extent the foundation surfaces may be exposed.
My question is regarding surfaces that cannot be exposed and the underside of the foundations:
Is there a system for injecting a protective grout into the soil and adjacent to the foundation surface that may act as a barrier to prevent sulfate attack?
I'm thinking of something where small boreholes may be installed near the foundation and then grout pressure injected around and below the foundation.
I don't know if that's a pipe dream or such system exists. If it does, I'm sure it will depend on the granularity of the soil, as I assume it would be
difficult to inject grout into cohesive soils / clays.
