Propane loading Pump-Pump Down curve
Dears,
I have received an NPSH curve from a cryogenic submerged pump Vendor in which a pump-down curve has been also provided (please refer to attached file for similar curve)
The pump is a propane cryogenic submerged type installed in a column inside the LPG tank and sends out the propane from LPG tank to loading port.
Could you, please let me know what is the purpose of pump-down curve for this pump?
Moreover, some levels have been specified with respect to pump bottom datum which is not clear for me:
1- Min start Level= wetted lower bearing
2- NPSHR level at 3% head drop [it is already clear]
3- Pump-down level at head drop (at rated flow)
4- Minimum pump-down=loss of prime (at minimum flow)
RE: Propane loading Pump-Pump Down curve
It's a new one on me, but my thinking is that if this is a pump suspended in a propane tank your liquid is essentially sitting right on the vapor pressure limit. Therefore the only effective NPSH is the liquid level to pump inlet height.
So by the look of it you need 2.0 (m??) liquid head for the pump to have it's 3% drop.
However that would leave a lot of propane in the tank so they are giving you the option to operate lower down at what seems to be a loss of 4.5%.
However I could be completely wrong...
Dear LittleInch,
Thank you for your reply.
For more information, please refer to the schematic attached to this thread.
Ok, that seems to back up what I was thinking. Basically
Don't start the pump with level less than A
Try not to run it below level B ( as you might damage the pump from cavitation)
If you need to empty the vessel start the pump with level above A and then you can run it down to level C, then at reduced flow level down to level D, but the pump might / probably will be cavitating so don't do it for very long.
Note that the NPSH level is not the same as onset of cavitation. If you operate close to (=1m) from level B then the pump could easily be cavitating even though it is above the NPSHR figure.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Research Report - How Engineers are Using Remote Access
Remote access enables engineers to work from anywhere provided they have an internet connection. We surveyed our audience of engineers, designers and product managers to learn how they use remote access within their organizations. We wanted to know which industries have adopted remote access, which software they are using, and what features matter most. Download Now
eBook - Managing the Context of Product Complexity Using the Digital Twin
Keeping track of changes to complex products is difficult—think Aerospace & Defense equipment, new generations of commercial aircraft, and software-based automobiles. A new way to managing the digital context of the physical product is required and the answer is the Digital Twin. This ebook explores the opportunity available for Operations and Maintenance for the Digital Twin. Download Now
White Paper - Trends in Industrial Filtration
Substantial progress has been made in filtration technologies in recent years. New filter media materials, designs and processes have led to filters that are more efficient, reliable, compact and longer lasting. This white paper will discuss the various trends that are impacting operational responsibilities of MROs today and the resources that are available for staying up-to-date on the latest filtration solutions. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
