Transient conrod analysis
Pablo_C2R
Automotive
MX
I am trying to perform a transient analysis of a crankshaft, conrod and piston in order to understand the effects of the reciprocating mass in the conrod performance (with lightening purposes). The project is set up with a 200 steps of 0.0002 sec and a configuration of 0.00005 sub steps with a joint rotation of 9000 rpm at the crank.
As you can see, the results are far from conclusive. I have tried mesh improvement and lowering the substeps time without any improvement in the results.
Do you have any advice.
Best regards.
 https://files.engineering.com/getfile.aspx?folder=c7ae4279-1bb6-4ebf-94a7-67a5977261da&file=Screenshot_20180707-104515.jpg
Make RBD analisys and export forces/velocities/accelerations to FEA linear or nonlinear analisys. Calculate only some critical points - with max loads or at fixed angles.
At this point you try to kill fly with nuke)
Thanks for your help karachun, that's a practical approach.
I reduced the impact of the oscillations reducing the acceleration ramp, checking the natural frequencies in a modal analysis and improving the joints.
What are your conclusions of the stress results in the picture?
