Impact analysis in ansys workbench
Good evening to everyone, I want to do impact analysis in ansys workbench, I got input as energy (5KJ) that will be impact in my object. I can’t able to apply as energy, any Idea like how to feed the inputs. I don’t have mass information I have only energy value, please let me know anybody know how to apply?
Senthil Ramajayam
RE: Impact analysis in ansys workbench
Describe problem more specific. Do you hit structure with bullet or drop structure onto ground?
Hi thanks for your reply. Solid object hitting the structure. So for I didn’t get actual mass of the object, customer gave only joule. He’s there any way i can to impact with joule value
Hi everyove
I know the energy value = 5 kJ. Using potential energy equation (PE=mgh). I know the object is hitting 500 mm radius (5000=m*9.81*.5) that gives mass value = 1019 kg. Can we use this mass value in kinematic equation to find velocity (KE= 0.5mv2).I assume (KE=PE),therefore my velocity v=3.13 m/sec.
please let me know whether this approach is ok or not.
Senthil Ramajayam
How do you use potential energy equation - what is h in your case? You have to make assumption about mass and then calculate velocity from kinetic energy. There are big difference between coin with 5kJ kinetic energy and pilow with same energy (also coin and pilow with same KE will hav different momentum).
h 500 mm.
what will be the solution ?
What is h? Can you show it on picture? I dont understand.
Now I understand. Yes your calculations look right.
But now you are facing new problem - impactor maus have some radius.
Radius value included in the calculation. What will be solution?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper – Data Security and Know-How Protection
Our data is constantly exposed to the danger of being intercepted or stolen as it wends its way over global data networks. Data security measures and measures for protecting intellectual property should not, however, first be implemented when data is exchanged – companies must lay the foundation for these measures within their own organization. Download Now
White Paper – Collaboration in the PLM Context
The influence exerted by the Internet of Things (IoT) means that there is a steadily growing need for collaboration in industry. Partners from new industries and areas of application need to be integrated in cross-company business processes to ensure that the lifecycle of smart, connected products can be managed from end to end. Download Now
White Paper – The Challenges of PLM Collaboration
There is cross-company collaboration - and then there is cross-company collaboration. Large-scale corporations and joint ventures need different mechanisms to protect intellectual property from those required for communication between different company locations with heterogeneous IT landscapes. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
