Pipe first circumstance weld joint type
Hello everyone,
In code AsME sec VIII Div 1, code scope limit as per U-1(e)(1)(-a) " the welding end connection for first circumferential joint for weld connections"
Here please confirm which type of circ. Joint ?
Butt joint or other( refer attachment)
Can attached joint here applicable
RE: Pipe first circumstance weld joint type
IMO, the first Code weld includes the first weld of either butt or fillet welds.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Close Box
Join Eng-Tips® Today!
Join Us             Close
