Joint efficiency where 3 welded joints join in
Cathie16
Materials
GB
Hello all,
we have a situation where the diameter of the header and nozzle are the same. So when we want to weld it together we arrive at a zone there will be atleast 3 welded joints join in. Could anyone tell what would be the joint efficency for such zone? is there any restriction for such zone in ASME?
Thanks in advance
Why 3 joints? Can't you rotate the pipe?
Anyway this is normal branch connection welding and in the ASME piping codes there is no issue.
what is this thing?
Which code?
If ASME VIII/1 is applicable read table UW-12. The joint shell to header is an corner joint, which means joint of type 7 and there is no Joint Efficiency.
Regards - Juergen
When the header is the same diameter as a nozzle, the best solution is a Tee. Is this route a possibility?
The devil is in the details; she also wears prada.
What size, what Code? Vessel? U-2(g) would be required.
